Re: Planning to buy A6 S-line 2009-2010 2.0TDI
Quote:
Originally Posted by
MarkTM
Erm Luke, it's the same poster on both.
Pay attention man!! :biglaugh:
Yep both of those posts from me. I thought would be better to open separate thread for it.
hufodorp
doh!
johnsimcox
The oil pump issue relates to the previous engine that was dropped with the facelift (basically any car 2008 or earlier although there will be a few very late 2008 that are facelift).
Unfortunately CR engines still carried 77mm hex oil pump shaft and vehicles as new as 2012 still have failing oil pumps.
The best mod is to use 1.9TDI PD130 oil pump. It's an engine out job, but it will never fail again.
crazy4alfa
Is there any engine which doesn't carry that issue? If yes how can I find out which one I got?
2.7 and 3.0 doesn't have a problem ;)
All 2.0tdi have the same pump.
hufodorp
That's bad :(
Is there any sign if the oil pump has already made a damage?
Can I do anything to prevent it to fail (something other than the 1.9TDI mod)
Nope, it's failed or not. It's around £600 to sort this issue. I think KMB parts direct can supply modified pump with 100mm hex shaft.
