Re: A6 3.0 TDI QUATTRO numbers
The fault used to come up rarely. Now its back every time i turn the ignition on. Also when i put the temp to HI i hear absolutely loud bubbling noise from the engine compartment. it reminds me of something just about to blow due to pressure issues. I turned the TEMP back to LO and it stopped! I wont be testing it again anytime soon just for the heck of it. Too scared tbh. :-(
My best guess is the gurgling that you are hearing is due fault with the coolant valve/pump in plenum chamber (V50)... IIRC the coolant is not only pumped around engine but gearbox and the AC/heater matrix... will fish out info if get my other PC online or find on web...
I would greatly appreciate it. I gave Audi a call today, got a few quotes...
Glow plugs
6 glow plugs @ $70.74 each
Labour 2.0 hours @ $176.00 per hour
Total est $778.00
Coolant Circulation Pump (V50)
Coolant pump/valve @ $1006.15
Labour 2.5 @ $176.00 per hour
Total est. $1447.00
Thats nearly 1500 pounds
:yikes:... that's expensive... I'll try to get a like quote from here for comparative...
Did you manage to get a quote? Nothing new on my side here. I've ordered all parts the only thing to arrive was the 3/8 to 1/4 socket adaptor enlarger. The rest is still 'travelling'. I swear i'd deliver it faster even if i had to go by foot to the buyer... I've taken 5 days off from work, so hopefully it arrives in that time and i get it all done. Will keep youse updated! :-)
Due to holiday season & being a bit snowed not yet got quote :Blush2:...
Will do soon as I need to get a quote for compression test ...
My glow plugs and some other parts arrived :) ...
3 Attachment(s)
got my tools..... Attachment 19009Attachment 19010Attachment 19011
its a nice set of tools... The glow plug kit is rubberised inside to be soft for the plugs...
Tools look fantastic! :fing02: ...
I saw you read the thread on "Signs of compression loss", Crasher (:approve:) gave some great tips on the glow plugs...
Sorry mate been snowed with own stuff :( ... I will email you stuff tonite or tomorrow so you can crack on... :beerchug:...
*** Update ***
Check your inbox ;) .... if you need anymore just mail :) ...
ATB
Gup
Quote:
Originally Posted by
Cwizard
I still can't get to the bottom of those revs jumping up and down while driving. I've even noticed since yesterday that my gearbox has been very clucky when changing into 3rd from 4th and into 5th from 4th.
Your symptoms seem to be more and more following the TPI Link:- ZF 6HP19A tiptronic gearbox (A6 3.0 TDI Quattro)
As discussed in IM I will do video of my MVB's of gearbox for you :) ...
Here is an extract from the TPI....
Quote:
Customer statement / workshop findings
2. Vibrations/juddering during the control phase of the converter clutch (see Note under Cause)
Vehicles with 6 speed automatic gearbox (09L).
Technical background
The clutch generates briefly (about 500 ms) noises or vibrations/juddering when changing gear.
Note: This entry only applies to vibrations/juddering during the control phase of the converter clutch.
The converter condition can be checked in MVB 007/3 (converter open/ convertercontrol/ converter
shut).
Thanks a bunch mate! Try giving yours a sip of wine :beerchug:(Liqui moly for diesel) and see if it makes a difference. I'm really curious.
I'll keep on scanning mine to see if any error codes come up. In the meantime... :confused:
