Had it tested for leaks. No leaks found absolutely air tight. Replacement throttle body has come and now have 16505 TPS Implausable Signal... We go back to wireing again... :S :confused:
Printable View
do you have a wiring diagram?
Yeah got one thanks, spoke to my auto sparky and he said he would take another look and see if any of the cable from the TB,Hall Sender, Air Intake Sensor, and then back to the ECU are faulty and replace if needed.
