Re: Genuine Audi Smart Phone Interface
Quote:
Originally Posted by
nbedford
My car is still on 0358, no ODBEleven. I have VCDS (but not hex-net :( ) Would consider purchasing VCP, if this was something that is possible, but finding decent info on VCP is hard with their private forums.
0358 definitely needs updating. You should be able to ask your dealer to update it to 0976. Mine started on 0358 and I updated it to 0976.
Can your vcds see module 5F? If it can, pm me an export of it if your OK too.
Dont get Vcp you don't need it. Your better off trading your hex-can into Ross tech for a hex-net.
Cheers. Andy.
Sent from my SM-G928F using Tapatalk
I'll try and get an export for you, I'm pretty sure I can see 5F, probably be sometime over the weekend
nbedford
No worries. Can you also take a pic of your USB ports under your arm rest please?
Andy
andyhud007
Andy
Purely from memory I don’t believe they were any different?
Nemo78
Pre ASI retrofit Q7s are different.. Very very slightly (visually). Need to confirm if that's indeed the case.
andyhud007
I will bow to your superior knowledge [emoji1360]
I can’t actually remember what the build date for my first Q was but delivery was very early Oct 15
1 Attachment(s)
Here's a picture of my USB ports, I'll try and get the export of 5F done over the weekend, but weather isn't looking great to be sat in car with laptop :(
Attachment 34614
Hi andy,
I've generated adpmap-5F-4M0-035-035-B.CSV from VCDS (i assume this is what you want), but call me stupid, but I cant figure how to add an attachment to PM?
Probably should put this in a new thread, but I was looking for options for my recently bought 2015 a6 Quattro. Too early for smart phone interface unfortunately. Frustratingly, it does not have sim slot, nor can the mmi (or mib?) tether data from a USB connected smart phone, so no Audi connect, google maps. What it can or is supposed to do is connect to the phone by the car wifi source AP for audio. Superior to BT streaming as the MMI and the Audi connect app allows the mmi to browse and control the phone, It has worked a few times, but stubbornly refuses to connect most days. As the phone connects to the car's wifi AP, but this AP does not have an actual internet connection, I think the Audi connect app as well as maybe dhcp is not functioning on the phone as it tries to connect to the net via the non internet car wifi. Maybe theres a way get the phone to continue to use 4g for data while connected. It has worked sporadically but then doesn't reconnect the next day. There are some (no sim slot) guys out there trying to route data back into mib via the USB connected to various hubs and cables, but I've not read a sucess story yet.
Audi Connect data tethering on MIB2
All this was doable 3rd party when the cars had the AMI plug, but this is gone since MIB.
Final question. What is the significance of the little mobile phone graphic over one of the USB ports? There's so much tech functionality missing for my spec, even though it has Nav high, the 3l turbo just about makes up for it.
