Re: Allroad Level Sensor Electrical Problem
Quote:
Originally Posted by
The-Stig
Hi Lee, thanks for the heads up, only thing is that im a newbie so haven't a clue, done some research about fault codes, is there anyone in the Leeds area with a reader who could help me?
My problem is that i bought my car a few days ago i read the buyer guide on here and knew what to look out for. The allroad i bought was a-ok but yesterday when i started her up i got a headlight alignment warning on and the air suspension light on! i thought ***?! SODS LAW!
The car drove 30-40 miles ok parked up went back couple of hours later and the warning was gone for the headlight but the suspension warning is still on with car stuck on 2 lights.
I think it must be the notorious ns front sensor problem! i shall have to get out tomorrow on all fours and locate the problem, hope its not too bad and a loose wire or so would be the likely culprit.
If its a sensor problem at least i know that you know a bloke who has some.
I shall investigate and update this thread also.
I had simular problems when the front left sensor (ns) (G78) went on mine. Suspension mil and xenon range warning on the dis. Im not to far from Leeds, North Barnsley only 10mins from Wakefield if you need a VAG-COM reading.
Lee
Hi, i know this is old but i have to try, have the same problem on my a6 allroad 2.7 bi turbo. Can really use that diagram you sent to snugglebum.
have replaced the sensor with no luck im thinking its an electrical problem now.
cheers
Christoffer
Fireghost
cheers
Christoffer
What is the fault codes on your car?
What year is the car?
Send me your email and I can send the wiring diagram
Regards
Andy
bagpipingandy
Regards
Andy
code is 00776, sensor has been changed.
I got 01776 some times.
It´s a 2000 year
have sent you a message with my email.
Best regards
Christoffer
Fireghost
It´s a 2000 year
Best regards
Christoffer
What is the fault code description? “Open or short to ground “ or “implausible signal”,
check wires just next the the level sensor common for one of them to be broken, or check plug under the rear bench seat, I will send diagram to your email
bagpipingandy
"Sensor faulty" some times other times "open or short to ground" and some "intermittent".
I have checked the plug under the seat and it looks fine. have to check the wiring.
Got the diagram thank you, it helped alot in my search.
