:biglaugh:
Printable View
:biglaugh:
Cheers, Is it easy to fit the different sensor at the rear?
And the original CAT is put back on before it goes for the MOT and then removed again afterwards. Although I may not bother next time.
Different sensor at the rear? I think you refer to the lambda cheater but that is a small electronic box that is wired in but I have never used one, I like them to work properly.
There is loads of info on o2 cheaters on the internet. I have same problem with my allroad at the moment. Have had it into the dealer and they tell me i need new cats fitted. But as long as it keeps passing its mot why should I? They are also refered to as "MIL eliminators". You can get plug and play units and self solder kits. But haven't found one for allroad yet. It's a 2000 2.7t. Does anyone know where I might find one?:1zhelp:
