i put petrol into my escort van once, 10.00 worth, realising my mistake i payed for the petrol and then put in 10.00 diesel on top. the van never skipped a beat.
Printable View
On a modern car you can't put diesel in a petrol, the nozzle just won't fit.
A Small amount of petrol wont hurt. a short distance with alot of petrol won't hurt either. But if you catch it right/wrong the petrol is highly flammable and you can get detonation and its lights out:(
Just drain the tank, flush the lines and replace empty the fuel filter. fill the tank with diesel then start,let the engine run until it runs smooth and all should be well.
:D
I don't know, I've a mechanic friend who worked on HGVs in the 80s, and according to him they had a direct injection diesel HGV that was filled with a full tank of petrol.
According to him, the petrol being thinner meant that once the diesel in the fuel line had been used up, the governor wasn't able to control the flow of the much thinner petrol.
The vehicle proceeded to do an impression of a runaway freight train, and being as diesel engines of the time had no electronics to speak of, even switching off the ignition did nothing to stop it running. In the end the driver had to leave it in gear and slam on the breaks to stall it - destroying the disks and pads in the process.
Apparently kicking it out of gear and stopping would just have meant it revved to self destruct.
Still, I'm not a mechanic myself so I may be believing a lie :)
I did this the other day in the wifes Golf... stopped for fuel and she was chatting away and I put just under £3 of petrol in it.... quickly shoved another £37 of diesel in the tank. Did she laugh:ojust a bit.
I suppose the refinement of a 1.9 Tdi from 1995 with zillions of miles made me forget:biglaugh:
