Hi Crasher
How and where do I check the oil?
Can I remover the oil pressure switch and install a oil pressure gauge there?
What sort of pressure should I see?
Printable View
Hi FrenchAudi
The current mileage is 106,000 miles. I purchased the car with 100,000 miles and service history to 88,000 and an odd couple of receipts after this mileage for oil and filter (but no details entered in the services book) So when I purchased the car I completed a oil and filter change at 100,000 miles using full synthetic oil. Since the fault occurred its also had another oil and filter change completed at 106,000 miles.
You mention you are fitting a oil pressure gauge, could you say how and where? (what pressure should I expect to see?)
Thanks for the info'.
I bought an M10 M x M10 F x 1/8" NPT F fitting from Speedograph Richfield, which screws into the M10 F hole where the normal oil pressure switch fits. The oil pressure switch goes into the female end, and the 1/8" NPT M sender for the Chinese oil pressure gauge I bought on Ebay goes into the side of the fitting. I don't care much about the accuracy of the gauge, I'm only interested in any change from the reading I normally get.
According to my Bentley manual, the pressure should be 1.0 to 3.5 bar at idle, and 5.0 to 7.0 bar at 3,000 rpm, with oil temperature at approx. 80șC.
Speedgraph Ritchfield at at the top of the road where Roy in our office lives, they make special handbrake cables for us. To test the pressure you need an M10 non tapered adapter for whichever gauge you use. The VAG book says 2 Bar at 2000rpm @ 80 degrees is the absolute minimum but I have found that you need to see at least 3 Bar at that point and at least 1.5 Bar at idle fully hot, preferably a bit more.
Hi Crasher and FrenchAudi
Oil pressure gauge fitted:
At tick over gauge shows 1.8>2 bar
At 3100RPM gauge shows 4.2 bar (no fluctuation)
Am I right in thinking I have low oil pressure? and time to pull the sump off again:confused::aargh4:
I will wait for confirmation
BTW. The thread for the oil pressure gauge on my (AEB) engine is M10 x 1 mm.
There are many Chinese made tees on Ebay described as 1/8" NPT Tee for tapping into oil pressure sender, with a diagram showing the 1/8" NPT connection on the side and M10 x 1, male and female, at each end. I suspect they are all from the same source.
I bought one, and found the end connections were M10 x 1.5.
The seller said they could not supply the item described, and offered to let me keep the fitting and make a refund of 30%, as they are liable for the return shipping, which is too expensive.
They suggested I could sell it to recoup my money.
I replied that I had no use for it, and would not accept a partial refund, and they refunded the full amount.
They have not changed the diagram with the wrong sizes. It does apparently fit some 2016 Audi petrol engines.
The adapter I bought from Speedograph Richfield Ltd is the only one I could find which was sure to have the correct threads, and it has :D
If those are the fully hot engine oil pressure figures they are fine.
My previous post was written while you were posting.
It seems you have slightly low oil pressure, but Crasher has far more experience with this issue on this engine than I have.
As you have already cleaned the oil pickup etc., this may be due to damaged bearings as he suggested, but could also be due to a faulty oil pressure relief valve or a worn oil pump.
As dropping your sump seems an easier job than on my car, it may be a good idea to replace your oil pump before looking at the crank bearings. You would probably replace the pump if you were putting in new bearings anyway.
I see I posted while Crasher was replying. As he says the pressure is fine, provided the engine is fully hot, I would suggest that a decision to replace the oil pump depends on how long you intend to keep the car, and, of course, the cost of the pump.
