Re: low oil pressure STOP, oil pump?
Quote:
Originally Posted by
aj1soad
Attachment 35779just got this from them so it doesnt look like theyve given me a price for the correct part, thats just the oil pump and not the kit or balance shaft
Wrong job - not likely to be anything wrong with the oil pump itself so no, this garage does not know the likely cause of the low oil pressure warning. Very outside chance of it being a failed oil pump or even failed oil pressure sensor but from what you have said about the sounds you heard and our experience of these engines tells most on here that it is likely to be the balance shaft and oil pump DRIVE bar.
Visual inspection the only way to confirm.
It will be gear driven , Kit 9 .
The only way you will know what to do is by dropping the sump. You have stated it has been worked on in this area before so no one has any idea what is in there
Hello aj1soad
If that light as come up on your dash. I would suggest you do not drive the car. You could be destroying your turbo and engine.
You will not be able to see the Allen key without taking off the sump. As it is within the balance shaft . That key is what spins the oil pump.
I am not as knowledgable as some people on here but I have done the replacement Allen key on My 08 Passat .
You will get some help from someone soon
I hopes this helps
I have the same problem with my car oil pump failure 🤦*♂️... Mine is an auto 2007 dsg... I've only just had mine replaced and a month later the oil pressure light has come on again 😔 don't know why it is failing or there could be other internal problems...
Nabz1310
I have the same problem with my car oil pump failure 臘*♂️... Mine is an auto 2007 dsg... I've only just had mine replaced and a month later the oil pressure light has come on again don't know why it is failing or there could be other internal problems...
What exactly did you replace ?
Gazwould
Just the oil pump from euro car parts bud and key
So the actual oil pump cassette and drive key .
You didn't address where the other end of the key goes , the balancer shaft keyway which would of been worn inside .
Gazwould
No buddy.. Unfortunately not... should have replaced that too. I'm guessing?? 😔 basically balance shaft and hex keys should have been replaced also? Links to pics would help me alot mate... Thanks in advance
