Re: Audi Drive Select (ADS) retrofitted
Chief Inspector, If you don't want to go adding wires etc, you can do as I have done and just have the ads activated via VCDS and use it via MMI. It does show an error message if you do a scan but you can ignore it. I might add the switch later but in the mean time mine is all through the MMI.
Quote:
Originally Posted by
a4audio
No, Audi specific part, so unless you can find a right off which is being broken for parts, the dealer is your best option. Even with all the parts from a deal, it's half the price of it factory fitted from new.
Ok thanks one thing do you think it's worth doing when I have no servotronic ? i would have no effect in the steering or would I?
i know you said you can make it hard but I'd really like to make it lighter as my power steering is quite hard anyway
Dieseldoos
whats the advantage off adding the switch? If you have it all ready? Would this way be better?
Dieseldoos
Thanks Diesel. This is something i might look to do in the future once i have had the car for a bit longer.
In dynamic mode the steering is more responsive and has less 'play' in the wheel. It's not any heavier to turn I don't think, infant maybe lighter at lower speeds for a sharper response.
"whats the advantage off adding the switch? If you have it all ready? Would this way be better?"
The only advantage for me adding the switch is it would stop the error message showing up when I do a scan. That said, it does not bother me to much as I know its only throwing the error up as the actual switch is not there.
I have a switch for an mmi car I purchased by mistake as I have a concert radio
can some one help? what am i doing wrong? I cab get as far as "Complete the above steps channels 63 64 65 66" in the guide but from here im lost!! I cant get the hidding menu up as i am holding down car and set up but noting is happen any ideas?
[QUOTE=shanekk;807831]can some one help? what am i doing wrong? I cab get as far as "Complete the above steps channels 63 64 65 66" in the guide but from here im lost!! I cant get the hidding menu up as i am holding down car and set up but noting is happen any ideas?[/QUOTE
Looks like you have to enable hidden menu function with cable first!
Any idea how?
I have try to go to 07-control head also try to go to 5F information - but I cant remember now but something like not found it says, so can my mmi not have the drive select on the screen? as i cant have a hidden menu any help please
