Re: MOT 6 years & 100k
I have to replace the washer jets (front & rear) before every MOT, they don't work because they are never used.
Why they get blocked is a mystery.
Any body got any tips to keep them clear without actually using them, they make such a mess of the clean look, especially the headlight washers.
^^^^ No idea why this would happen Roy...is there a chance there's crud in your washer reservoir or else in your pipes?
Only thing I can think of is getting the tank emptyand then topping up with hot (not boiling) water then draining...either through using them constantly then from the bottom of the tank.
I thought you'd pulled the fuse to disable the headlight washers...but am guessing you have to reconnect for MOT?
Yeah probably about right Mark and then some, we've seen some -3c already late at night / early doors, with dense fog early this am.
Mot around March there or thererabouts.
