Hello there, Basically I just pulled out the Hazard light switch from the centre console, disconnected the wiring then gave it a quick spray with WD40, reconnected it then put it back, also gave a quick spray to the workings of the indicator arm on the steering column (just stuck the tube in and gave it a quick blast!)
Have had no problem at all with the indicators since!! (a year now!)
Hope it works for you.
