Got help from the ross tech forum!
Here is the solution for this issue:
Change LCode Bit - YouTube
Printable View
Hi, I also have a Q5 FY and live in Australia, none of the following Unit A5 adaptations show in the list of choices:
"display end of speed limit symbol" change the value to "active"
"display no passing allowed" change the value to "active"
"display valid additional signs" and check if the value is 00100111
However the following Unit A5 adaptation does show in the choices:
"road sign detection fusion mode" change the value to "fusion"
Is anyone able to assist with identifying what the cause of this problem might be?
Thanks.
Hello, i have a problem to coding traffic signs in a6 Bj. 2012
Can you give me instructions on how you can encode it? (audi100)
I have a VCP
My Image Driver 8E - 4G0907107B
when trying to load the VCP data controller is a write error.
Thank You for any help
The 8E module has to be xxxxxxxD or higher. You need to get the camera software updated or replaced with a newer one.. I’ve got xxxxxxxE and had no problems regarding to the coding.
Have You done parametrization like in the video :
Afs parametrization by Vag Can Pro - YouTube
No problem. I have 4g0907107e.frf. I can flash on xxxxxxxxxE. Only vcp has no file for parameterization E. There is only B and D.
Ask VCP support (submit support ticket) for missing ZDC files. All versions are available.
I have just retrofited this to my A7 2010. I will be posting full in depth guide within a week or so (I am currently writing an update to ALA retrofit)
Check on VCP forum if you can flash B to any higher SW. I have just damaged my 4H0907107 by flashing with 4G0907107F using VCP so be careful!
B version support Traffic Singns so no flashing should be required.
Sent from my GT-I9505 using Tapatalk
My cam sw: 4G0907217
Your camera does support Trafgic Singns
