Hi guys. I'm a new A7 owner and would love to get a bit of help activating some of these features if anyone has a bit of spare time. I don't have VCDS so if anyone in the Maidenhead / High Wycombe / Slough area can help I'd really appreciate it!
Printable View
I'm in Harrow and happy to help, may not be the closest.
Thanks Jay, much appreciated. I'll drop you a message to exchange details. ...not being close just means I get to drive my new (new to me) car!
Did anyone ever try to change around on the ride height on the level control settings?
If you’re asking about lowering then I can share my experience.
First thing to note (and confuse), all wheels measured 388mm from centre to wheel arch, however the values in VCDS were all different and ranged from 401.8 down to around 385.
I then set them all at 400, but that left the wheel centre to arch all over the place!
Then added my required drop level to all the original number (ie, the recommended max drop is 17mm, so the original high one became 418.8.
However the adaptation numbers would not be accepted, and the highest number (most dropped position) was 426. So in order for all corners to have the same drop I needed to add 14.2 to the other corners.
After doing this I remeasured the corners and they were around 374, with a mm or so different.
My OCD wants to get them all the same so will need to do some fine tuning.
Hi just bought an Audi A7 Quattro diesel and there is white smoke coming from the front wheels when I take a hard corner .
Any ideas I have no clue
Hi - does anyone know what the maximum temperature setting can be for the heated steering wheel m on an Audi A7 2012? Have it set to 32c but could do with being higher but dont want to burn it out! Thanks in advance.
I don't think, that you can burn it out with the factory settings. However it's possible that the higher temperature will shorten the lifecycle of the heating element, but also IMHO, it does not depend on the temperature but on the total usage time.
Thanks for responding. Makes sense
