what year was the common rail engine introduced in the 2.0 tdi?
i've heard problems with 2005 year cars, so should i be looking at a 2006 year plate?
Re: what year was the common rail engine introduced in the 2.0 tdi?
Common rail in A3 came in 2009.
whats the difference in a 2006 2.0 tdi and the 2009 engine?
Loads!!!
The 2006 TDI is PD (unit injector) ie 4 injector units that are operted by the exhaust cam, they're fired by the engine control unit.
The 2009 is common rail ie one high pressure pump that feeds a fuel rail which supplies fuel to the injectors, they are fired by the engine control unit.
The CR engine is "cleaner" as it meets later emmission standards. The PD engine is good, but as with evolution, the CR is better.
Having come from a 2007 Passat to a new A3, the difference between the PD and the CR engine is very evident. THe CR is much quieter and smoother, and the DPF is amazing - the exhaust pipe is totally clean, no soot whatsoever.
"Progress" isn't always for the better, but in this case it definitely is.
so you need to guy a 2009 year a3, too expensive for me at the moment:(
