Rear Brake discs
Hi, I'm in the process of trying to replace my rear discs/pads on my 96 1.8se (ADR). But I'm struggling to confirm what discs I need.
I can't quite make out the part number on the disc, but I'm reasonably sure it says 8D0 615 601 B.
Can someone please confirm that for me? As this site says that it's not for the ADR; http://www.yiparts.com/Part/es/SWPPS
Many thanks to anyone that can help me track down the correct disc/pads :)
Re: Rear Brake discs
Yes that part number matches and old invoice for my old B5 ADR. You will need rotors for abs too, and seals.
Rotor = 443614149A
Seal = 8D0501641A
I swapped everything over on mine. The abs ring comes away easily, and aslong as you dont butcher the old oli seals tey will go straight in:beerchug:
Lucky you ! But i wouldn`t use old grease seals.
Yep, was indeed the correct part number :)
The rear bearings were swapped about this time last year by the previous owner, so the bearings and seals were easy as pie to swap over, the ABS ring was a little rusted, as expected from a 15 year old car, but that's to be expected, lol. They still swapped over easy as pie.
Apart from some muppet mullering the security bolt on one of the wheels, all was a sinch :)
Ended up getting the parts from ECP, £48 inc p&p for eicher discs/pads, arrived in 22 hours, gotta love 'em :)
