Rear Door won't open
My rear door (drivers side) won't open - from inside or out.
I have managed to remove the door card - not easy, but possible if you remove the base of the rear seat and the trim over the rear wheel arch.
I am now faced with another metal plate inside the door - retained by bolts.
- If I remove this, will I then be able to open the door by manually accessing the catch ?
- When removing inner door plate, should the window be "up" or "down"
I suspect the problem is either mechanical - ie need to replace door catch, or electrical due to cracked solder joints in the door handle module.
any help appreciated :1zhelp:
