locked rear drivers side passenger door
Three friends, three Passats (all 97's) and all with the same locking problem in drivers side rear. The door doesn't respond to central locking or manual opening, as pin will rise when handle pulled but drops back down immediately when released. Also water leaking in slowly but surely through bottom seal. Any suggestions?
Why does so much water get into the Passat? So far had pollen filter gasket leak (knackering the loom), boot leak into left hand side pocket and now rear door leak!?!
Many thanks
