Hi I have a mk4 tdi 130 and my speedo stopped working, my fuel shows empty when cornering and buzzer goes off has anybody any ideas???? :1zhelp:
Printable View
Yes it sounds like the common cluster failure issue to me.
If you can't get it fixed any other way then I can code in a second hand cluster for you and correct the mileage to suit, much cheaper than hundreds of pounds at the dealer for a brand new cluster!!
hi thanks for that can you supply and code is it a straight swop or does it have to go to vw
Hi thanks for your advice how much can you supply a cluster for?the part no on mine is1JO920926CX VDOthanks again
Hi sorry I must have missed your reply.
The X on the end means that your car has already had a replacement cluster at some point in it's life.
I don't usually supply clusters but I can try to find one for you - drop me an email (address on the website - http://www.sharkperformance.co.uk) and I'll be in touch.
Ben
