which side is it located in the engine bay?
car's an 05 1.9 TDi
got a squeak and I'm losing coolant
is it a DIY job?
if not a DIY job how much could I expect to pay in a non main dealer garage?
Printable View
car's an 05 1.9 TDi
is it a DIY job?
log book says car has the following engine spec AWX 455763
Water pump is driven by the timing belt, if it is the pump that is at fault then you may as well have a new timing kit fitted! about £250 to £300!
P.S one other thing if it is the pump making that noise DONT RUN THE ENGINE OR DRIVE THE CAR ANYMORE!
turns out it's the radiator that's split on the left hand side not the pump failing
changing the cambelt, pump and rad whilst the fronts off
