Phone cradle
I have recently purchased a used A4 Avant S Line 2.0 TDI, it is the older 2008 model. I have a Nokia E51 mobile phone that I would like to use with the phone cradle that protrudes on a short stem off the dashboard. I have checked with the dealership today and they want to charge me £98 for the accessory required. Can anyone tell me what it is that I need and if it is possible to purchase these more economically elsewhere as I went over budget in acquiring the car but do enjoy using it. Many thanks in advance, Adrian
Re: Phone cradle
Ebayis probably your only other option if you can find one as they are of course different for each phone model. they arent cheap. I'd not bother with it personally, just use the Bluetooth instead - wont cost a penny!
Re: Phone cradle
Many thanks.
I have just been reading a previous post about this.
Is it easy enough to set up?
Re: Phone cradle
Yes its all in the manual. Basiclly search for the car from your phone within 5 minutes of turning on the ignition.
Re: Phone cradle
I shall try that tomorrow. Many thanks.
Re: Phone cradle
Search device then you will see audi uhv connect enter pin 1234 in the phone and that's it.Rember this bt unit is universal prep so without the cradle you are using your phones gsm so calls are more likely to suffer from interference and poor volume quality.
