Re: Stuttering under load.
what was the code ? have you rechecked the timing ?
The fault was : 19463 camshaft position sensor (G40) No signal P3007 - 35 - 10 ---- intermittant.
I too wondered if the timing was out .
I originally thought i had the cam 180 degrees out, I rechecked the timing & ensured everything was lined up. The crank was locked in position. The cam lined up with the pointer and a drill bit inserted. Then when belt was on the engine was manually turned over a few times & the pointer from the cam was just pointing to the bottom between the guides on the head. I i would have tried to get closer to the centre but then i would have had to move a tooth which was way to much.i got all the data from autodata.
i would check the signals with an osilloscope to see what is happening,if you dont have one somebody near you might be able to help tho
ok but this is not a constant fault, i noticed today it only happens between 2000 & 3000 rpm where it seems first of all flat then stutters then picks up. It is also difficult to start, where before it would turn over straight away. could the glow plugs have been damaged when the belt went? Could it also be the tappets need adjusting where they have been replaced or one of the injectors. I noticed when i put it back together one was a bit of centre. Do they need to be lined up exactly?
It's one of those faults where i'm looking into everything... & doubting all i did....
it could be an injector fault on a pd engine if one loses pressure then it wont start very well,but they tend not to start when the engine is hot as well,the tappetts are hydraulic so no way to adjust them.the injectors need to be in line or they can come loose,have you tried resetting the injectors ?
resetting? do you mean taking them out & realigning them?
no,you set the length of travel the piston moves inside the injector
i have sent you an e mail
