Re: Warning Light... Help!
OK, Checked through the forum and it seems it could be the brake lights. I've checked the car and the rear lights are out including the one on the back shelf. I'm going to try new bulbs now but if that doesn't work how difficult is the brake switch, mentioned in another post, to put in myself?
Thanks,
Geoff
Piece of cake to fit and relatively cheap as well. When I did mine it cost about 6quid from a main dealer for the part.
The switch is above the brake pedal in the footwell. I can't remember the exact procedure (ie whether I had to take trim off etc) as it was quite some time ago and my memory is rubbish but it is simply a case of removing the exisiting switch (screws + plug) and fitting the new one.
Cheers for that. All up and runing again.
Geoff
