big problems after fitting a new car battery
Hi all firstly what a great passat forum after reading a lot off posts and picking up some great tip’s. The car is a 98/99 vw passat 1.8t 20v sport. ok my problem first started after I fitted a new car battery (I had no problems with the car until I did) then I noticed that if I gave a quick rev to the engine or coming to a stop on the road it would dip down to 600 rpm as if to stall then rev up a bit then back down then it would level out to its normal rev about 900 rpm plus under the bonnet it sounded like a lot off tapping noise which was never there before.plus on the lcd screen the mph was well out sometimes stuck .again on the lcd screen the mpg would show 24-35 then shoot up to 200 mpg then level back down . I took the car to vw and was told that after the battery is disconnected that all the learned values are erased on the ecu and all the basic settings would have to reinstate by vw .so after two hours waiting about and £60+ after two half hours it was ready but as I jumped in and started the car it was just the same the engine was erratic tick over. so it when back in today to have it done all over again and was told they do not have a clue as yet to what is causeing the problem with out having the car for a full day£££££££,on the full elec test no problems was found everything was ok no faultys .firstly has anyone had this problem after changing the battery ,plus if the battery ever goes flat again will I have to get vw to have the basic settings installed again.lastly what are the basic settings .yours thankfully Justin
