allroad probs
1 Fault Found:
17539 - Oxygen (Lambda) Sensor: B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
1 Fault Found:
17125 - Torque Converter Clutch Circuit Performance or Stuck Off.
P0741 - 35-10 - - - Intermittent
Any ideas peeps? Car drives ok, autobox is a bit sluggish
Re: allroad probs
check this out
http://wiki.ross-tech.com/index.php/17125/P0741/001857
has the atf fluid ever been changed
seems like lambde sensor faulty but dont change it yet
clear all codes and rescan in a few days
paul
Re: allroad probs
good stuff.
I have cleared the codes
will give it a couple of days and re test
120k on the car, the 'lifetime' auto box fluid must be well manky!
is the lambda probe an Audi only part?
Rob
Re: allroad probs
auto fluid is best changed every 40K, so you need to change the oil and filter. You will notice a difference in the drive !
just remember you must have VAG-COM, and use the correct oil, not dextron
As for lambda sensor plenty of people sell them
Re: allroad probs
Lamda probes are £96 +vat for the front probes and £117+vat for the rear probes from audi. Have gotten them down to £65+vat each just be a couple of calls. The LT71141 fluid seems to be a hard thing to det. £107+vat for 20 litres is the cheapest I have seen it so far. Cheers for the top responses folks.
Rob
Re: allroad probs
try http://www.wessexpetroleum.com/
I paid £61 inc. Vat 2 years ago for 20 litres.
It is expensive, but nothing like what Audi charge.
Even with the increases in oil costs would hope it was not as much as you have been quoted
