Re: Multitronic Service??
To fill correctly there is a special filler (gravity filler)and the oil level is filled from the underside further more oil temp requires monitoring via vag com so the level is correct.
pass me your email and I will send instructions
I`m not sure you want to use ATF. I believe multitronics use a completely different type of oil.
ATF is short for "automatic transmission fluid" which is what multitronic requires. however the spec differs from other ATF fluids and the correct part number is G052 180 A2.
Just been quoted £120 from a local specialist to do a flush and refill. Is this about right??
P.s. A local gearbox specialist quoted almost double that......:aargh4:
The oil is very expensive, about £15 per litre I believe and I think it takes 7 or 8 litres. So I`d be a bit cautious of that price & make sure they`re putting the right stuff in.
Oil is about £10 and it requires 5 litres, so £120 is good value. Just make sure they measure the temperature when filling.
Have it done by your Audi dealer. Its just not worth the risk to do otherwise!
