Re: Intermittant engin noise
It sounds as if it's just the DPF regenerating itself. The warning light should come on only when it gets too blocked, and usually the engine runs slightly differently during the regeneration process.
There may be another problem, but from what you describe it sounds perfectly normal to me.
I don't get issues with teh engine, but often can smell a burning coming from the back of the car, like rubber, would that be caused by the DPF?
Quote:
Originally Posted by
ledburyloafer
Yep. I don't know the exact temperature at which the DPF burns off deposits during regeneration on a VW, but many of them go up to 600 degrees celsius internally, hence the burning smell.
Some of the early X type Jags with DPF had poor heat shields around the DPF and if parked up during regeneration the car could catch fire due to the heat - not good, and not something I've heard of on VW's - yet.
