In conjunction with my DIS upgrade I'd like to add a windscreen washer level warning sensor. Unfortunately there seems to be no room to get to the washer bottle as there are two intercoolers on a TDi170 - is there an easy way of doing it? Thanks
Printable View
Wheel off, wheel arch lining out... Couple of bolts and its out... Sensor replaces a rubber bung. Earth a cable, in to the sensor, out of the sensor along the top of the wing and through the rubber grommet in to the passenger foot well. Then I *think* it is pin 9 in the black connector down there... I can't remember exactly as it was so long ago I did mine, but you can check the wire colours of the wire out of pin 1 in the instrument cluster and then confirm with a circuit tester (like I did)... Just use the relevant repair wire and you don't have to use any Scotchblok bodging... A very easy mod.
Flakmunky your replys are concise and excellent - great stuff!
np, mate... dead easy mod and it is so good NOT to run out of screen wash when you need it!
