Unable to change Adaption settings
Hi Doe's anyone have any experience the 'adaptions' i've recently changed my convenience module in my audi A4 but im told i need to set the adaptions correctly to recognise my coded key fobs. The problem i have is that with VAG COM i can't change anu values in adaptions, i get an error saying my software is not recognised, which it is. However if i plug my old module back in i'm able to get into that section..
Confused..:(
Anyone got any ideas?
Many thanks
Re: Unable to change Adaption settings
is it the same part number ?to recode the keys you will need both keys what car is it
Thanks for the reply, yes the new module had exactly the same part number, even the final letters were the same.
I have both keys yes.
then you must have a faulty unit,it carnt be the wiring or it wouldnt talk to the old unit,it should talk to the new unit straight away for you to change the coding and i believe you only have to match the remotes
well thats the odd thing, because it does talk to the module but doesnt allow me to change settings in 'adaptation'.
so you can change them on the old but not the new ? what version of vcds are you using ?
Yes thats right, thats whats puzzling me!
vcd's... ? do you mean version of VAG COM ? if so 409-1
Quote:
Originally Posted by
Sparky69
VCDSis the new name for VAG-COM. As for 409-1 it needs to be registered for adaptions.:(
If it's registered you can upgrade. (It's free) the latest version is 805-04. Also some of the fleabay interfaces don't work that well...
