2.6 '95' Coupe Starting problem
Having an intermittent problem with a 2.6 1995 Coupe. The starter motor is fine but the engine sometimes will not fire, sometimes it will not fire when cold and sometimes when the engine is warm. It will either not fire at all or more recently it catches about once a second but will not run. Eventually it will run but after some time. Once it does fire, it runs normally and drives fine. There is a laserline after market immobiliser fitted which could be a source of problems but I wonder if there is a known cause out there. Help, it is driving me closer to our white coated friends... Any clues?
Re: 2.6 '95' Coupe Starting problem
Hi Kenny, Good news, got the baby started today..... very pleased .. it was a vry simple fix...jacked the car up and noticed a sensor hanging loose.
and it turns out that it was the crank sensor...just could not figure initially where it was located...
thanks to all ..
