power loss
hi guys newbie here, i am having bother with my tdi 115.its the same old story of losing power around 2500rpm but ok after switching off and on,i have just changed the maf sensor as this seems to be the common fault but the problem still occurs and also have a bit of jerking around 1750rpm only after fitting the new maf sensor.
so i am not sure if i have baught a faulty sensor or if the problem is somewere else eg.turbo.
any help would be great i have read a lot of other threads on this topic but still unsure.
also there is a loud whistle on boost not sure if this is part of the problem or not
any help thanks.Robbie:aargh4:
Re: power loss
Where did you buy the Air Mass Meter (AMM)? If it is a Bosch saying made in China these are causing huge problems, you should only buy them genuine exchange from a VW dealer. The 115PS AJM engines do have a little more turbo whistle than other PD engines but I suspect that if you have a fault code read done it will show code 17965 Boost pressure exceeded.
Re: power loss
it was off ebay!so probably faulty.my fault for buying cheap sh*te:biglaugh:
it is a very loud whistle not used to td's tho this is my first diesel cant believe how many mpg i can get.my last car was only 20-25mpg!
Re: power loss
Well first of all you need to get it to a garage that can do a fault code read and it would be very helpful if these codes are in VAG or P format. Make sure you get a printout and then post the codes on here. As you will still have the original AMM, take a trip to a VW dealer and get a VW exchange unit which will cost you about £75.
Re: power loss
hi had look under the bonnet before and have found that there is a little sensor type thing (not sure what it is!)it seems to connect onto some braided hoses on the baulkhead.whell this sensor has came away from its mounting point and sitting on the exhaust and the pipe that is connected is freyed and think it could be leaking.going to get new hose tomorrow and see what happens.
Re: power loss
That will be the EGR, N75 or shut of flap solenoid but a leak in the vacuum system will cause a loss of turbo control and limp mode accompanied by code 17964 stored on the ECU.
Re: power loss
thanks mate your a star.gona get new hose tomorow and got access to vag com on tues so will see what comes up.thanks again robbie.:beerchug:
Re: power loss
hi guys had my car on diagnostics,got fault code and shows up to be turbo wastegate regulating valve.got a printout of voltage checks to carry out but might just get new one.
Re: power loss
What was the fault code number?
Re: power loss
hi its took ages to get round to it but i have a code it is 17965 turbo presssure control limit exceded int.ive been told it is the turbo pressure regulator valve and the vacuum unit on actuator is not working as it should.
any advice would be great thanks rob.
