Re: 1995 jetta not starting
Hi If you jumped the positive wire to the solenoid and nothing,check the engine earthing strap,if ok,then your starter is faulty
Thank You Kenny for your reply. It's not the starter or solenoid. I'm not getting power through the circuit to the solenoid switch. Any ideas has to how to trace circuit from ignition switch to solenoid?
The wire runs from the ignition switch to connector H1/1 on the back of the fuse box and out from connector F/1 on the back of the fuse box direct to the starter solenoid. H1 is a red 10 pin connector and F is white 10 pin connector
Thanks again Kenny I'll check the circuits. This has been a most frustrating problem and you are the only source I have that knows what you're doing. Thanks Again.
