Anyone know how, or even if it is possible, to enable anti hijacking locks on an allroad so the car automatically locks itself when you drive away? Does the ******* have to do it?
Thanks in advance.
Printable View
Thanks in advance.
Yes it is possible
Yes a dealer can do it but also someone with VAG-COM can do it for you
Where are you - have a look here for user locations https://www.vwaudiforum.co.uk/forum/s...ead.php?t=5319
And welcome aboard!
Thanks for the info and the welcome!!
Is it possible to do this without a vag-com? Either via a 'secret' shortcut or a hidden menu for user defined settings??
2006 - the last one sold in the country of it's type! (not the current model that has been out about 6 months) It's also a 2.5TDi 180bhp if it matters.
I only ask as I can easily do such things on my Golf.
Then you may well be able to, but I wouldn't know how.
I've had a look at www.ross-tech.com (makers of VAG-COM) for more info and have found the following;
http://wiki.ross-tech.com/index.php/Audi_A6/S6_(4F)
From that, if I'm reading it correctly, it doesn't appear you can code your doors to lock :(
Maybe ring your local dealership to see what they say?
Ok, many thanks for your efforts
