Re: Single din to double din
There is quite a lot of dismantling involved and you will need a clima fascia / cage off a B5.5 Passat where the clima lives on the bottom.
Quote:
Originally Posted by
BigCol
As Big Col said and the inside cage needs butchering for the double din cage to fit and you have to live with it as its ireversible ! You will need also a double din spec climatronic surround as its smaller and different than the single din one. Been there done that...If you have a dremmel, it will come in very handy.
thanks for the advice, any idea where i could get the surround?
many thanks
Hi, the parts you need can be bought from a VW dealer or off Ebay (Germany),The job is quite involved but also quite easy. You just have to be carefull with the dremel and ease off only what you dont need.
If you send me a PM with an emails address I can send you staged pics of when I did mine. There is two parts you must not cut as they will be required to fix the new bits to.
To help you. see these posts:-
http://www.passatworld.com/forums/sh...d.php?t=102382
http://cgi.ebay.de/VW-Passat-3B-BG-D...1%7C240%3A1318
The German supplier was easy to deal with and it was genuine VW parts
just be sure to specify what finish you require, Carbon effect, wood ect.
I also have an MFD "G" with genuine disk, satnav arial, and the plug and play lead in very good condition and fully working if you are interested.
Regards Richard.
Thanks Richard my e-mail is scs1@sky.com, the pictures would be a great help. i think the only other kit i need is the plug and play lead
regards
richard@thebrae
Regards Richard.
Hi Richard! I have a 2002 passat with single din and I'm looking to buy a 7" in-dash double din headunit. If i bought this double din cage with all the surrounds, do you think I would be able to fit in any aftermarket double din unit? Also, could you send me the pictures when you did yours,please? I think they would come in handy.:Blush: My e-mail address is zsagi1@hotmail.com
Your reply or any suggestion would be very much appreciated.
Regards
