Re: Windscreen Washer Pipe
Yeah, a design flaw. It's quite a common fault. VW don't seem to be very good with washer hoses. The hoses on older polos and the MK4 golfs were always coming apart and leaking water into the electrics and now this problem with jettas and MK5 golfs. The hose is far too rigid in this area where it is flexing every time you open the bonnet.
Regards - Jim.
I had a similar problem. Filled the washers up and on the way to wrok tried to clean the screen but nothing came out.:zx11::zx11::zx11:
When I parked up I tired again and notice that water was spraying from the side of the bonnet. Opened the bonnet and found that the hose was snapped. Thought that I had maybe snagged the hose . Did not really want to take car to VW as I thought that they may have charged so found a small thin tube that fitted inside the original tube push this inside both bits and retapped and he presto now problems since...........:biglaugh::biglaugh:
Having now read the post I agree that it is a poor design as the plastic does become very britle.
