A4 B7 Headlamp Bulb Replacement
Can anyone confirm that the B6 headlamp guide which is here:
https://www.vwaudiforum.co.uk/forum/s...ead.php?t=7485
... is accurate for the B7, or is there anything else I need to know before I try to tackle the job (considering I'm a mechanical numpty)? Also, I bought a Halfords headlamp bulb no. 477 (12V 55W) because that seemed to be the right unit according to the bulb finder in Halfords, but I wasn't entirely sure. Before I go unscrewing the front of the car can someone confirm this is the right bulb? Ta.
Re: A4 B7 Headlamp Bulb Replacement
Quote:
Originally Posted by
54A4Avant
the bulb you need is a H7 bulb, replace them in pairs! as you will get wony lights.
as for the fitting thats all worng, I did my dipped and full beams this morning in about 15mins! its dead easy!!! the only tools you need is a X head screw driver to remove the air intake on the rh side.
unscrew the 2 small screws on the front pannel that hold the air intake in place, then pull up out of the air box and then rewards to remove from the grill area.
then undo the cover over the back of the light, hold the black connector and twist to pop the top of the bulb out and then remove the bottom - you will understand when you see it - then draw the bulb out, replace with the new one - DO NOT touch the bulb!!! - then refit which is the reverse, put the bottom back in first and the tilt to clip the top in.
then refit the cover on the back of the unit.
this is also covered in the drivers hand book,
Thanks for the reply but is this definately valid for a 54 registration car? I looked in my owners manual by the way and all it says is that bulbs must be changed by a qualified service technician.
Do you have a B7 shape A4- I thought B7 was from 2005 '05' onwards.
kodkod.84
correct, a 54plate will be a B6, so what Ive posted will be wrong i suspect.
Karl
I have a 54 plate B7, registered in Jan 05!
54 plates run from September 04 to end Feb 05 (afaik).
Do you have the B7 54A4Avant, like this car:
http://upload.wikimedia.org/wikipedi...4.jpg/250px-05
Or a B6 like this car:
http://upload.wikimedia.org/wikipedi...px-Audi_A4.jpg
I have a B7- and the owners manual I have explains how to replace headlight bulbs.
Oh wait a minute - suddenly the realisation strikes I don't know what I'm talking about...! Much to my surprise it turns out I have a B6 so I'm in the wrong forum. Sorry guys!
No worries- the B6 section has a sticky thread all about replacing headlight bulbs that should help you out
