Re: Radio Ignition live fuse
their are some more fuses under the battery lid i believe,though don't know what they
are?
stewy.
hi thanks for reply. No, they are the 30amp big boys and they are all fine..i'm wondering if the fuse is note just to do with the radio (although that's how i popped it), but it's a main ignition live fuse?? although other things on the ignition work fine..
strange..any other ideas?
if you have other live feeds from the ignition switch, is the fuse you have blown not inside
the radio itself?
you could use on of the other feeds if you get stuck,though the key would need to be turned to operate,rather than just in the barrel.
stewy.
looking through my book,it should be marked with a radio pic. it should be in the area you have looked in the drivers side. if all ok,then it must be inside the radio,though not mentioned in the radio section?
stewy.
