Re: Phatbox error experts
I have a Phatbox in the wifes TT.
Have you selected the correct head unit ?
I found the best forum for P'box problems is
http://forum.phathack.com/index.php
Thanks.
By slecting the correct unit I assume you mean have I put right firmware on ?
I got the 7.02 audi phatbox f/w and it is on the cartridge. When I plug it altogether the red light flashes and sometimes the red and green lights flash together at 3 second intervals. The disc in the cartridge does not sound as if it is spinning in the keg. It works fine when hooked up to the PC.
Yes I posted on the phathack forums earlier today so hopefully someone will have an answer.
Kite, are you anywhere near the midlands ? Vortech on phathack suggested that the IDE controller maybe gone on my keg, to make sure it is nothing else just needed to plug the unit into a working setup and check whether it did the same thing. If it worked then I would recheck my wiring as that is the only other variable.
