1999 Toledo Brake bleeding
Hi Guy's,
got a prob with bleeding my brake on a 1999 Toledo V5.
Basically we are getting no Luck.
I do have Vag-com but when I go into Basic settings and enter 001 in group, then hit go, Vag-com asks to depress pedal, hold and then release which is ok but then get an error message saying something like Group 001 nor supported or something.
I also have a fault code of 01276- ABS hydraulic pump...........I maybe being thick but does that mean that problem I'm getting with basic settings in Vad-com is due to the facr that the ABS pump is not working hence the ABS bleeding procedure in basic settings does not work??
any help would be much appreciated.
many thanks.
