Re: audi 80 will not start
Quote:
Originally Posted by
rollerman
hi everybody rollerman back .can anybody tell me if there is a master key for audi 80 1994 model tryed every way to start mine after it was left for a while with flat battery tryed everything will not turn over even tryed to bump start nothing run great before baterry went flat nobody seems to whats wrong hope somebody out there can help thanks in advance
Hello rollerman if your model has a chipped key there should be
a key display on dash
Did you try recharging your battery?
the fuel pump solenoid would probably need 12v
to allow fuel to pump
Another thing to try is clean battery poles with
emery paper also inside battery connections
then remove earth connection that is connected
to gearbox and clean its contact points
