Re: temp gauge on a 2.5 t4
Coolant temperature gauge sender is the 4 pin plug,the 2 pin plug is the temp sensor for the ECU.If you are quick you can insert a new sensor without loosing too much coolant
thank you kenny i'll order it tomorrow. i was just confused cos the bloke in the shop was saying the other one and i thought i should check thanks again nic
yeah changed the sender tonight and now the gauge works, spot on kenny i hardly lost any coolent thanks again
