Re: VW/Audi CAN BUS VAG 5053
Hi Skodaman,
I bought a VAG5053 also. Did you ever get any guidance on how to reset the service ndicator?
I asked my ebay seller, but a waste of time. I intend to send the tool back, or have you found a useful way through the menu and code blocks?
Dave Everitt
Um... why don't you just do it manually? I wouldn't use a 5053, nothing is as good as vag com.
procedure for manual reset:
1. Switch off the ignition and press the reset knob of the trip counter below the speedometer and hold.
2. Switch on the ignition and release the reset button, one of the service events appear in the display.
3. It is possible to switch between the the readouts of the service events by briefly pressing the reset button.
4. When the particular service event is displayed, turn the button for setting the digital clock to the right, "service---" appears in the display.
5. Switch off the ignition. Only now is the service event reset.
HTH, Greg.
Have to agree, though I think reseting it manually does flag up in VAGCOM that it has been done.
