Head Gasket? Coolant incompatibilty?
Hi everybody!
I'm flummoxed.
1. I flushed and changed the coolant in my A4 V6 2.8 to normal blue coolant.
2. Car overheated and had brown foam in the header tank.
3. Thought it must be a head gasket, so I changed both head gaskets. Both looked fine and the heads weren't warped.
4. Flushed the system out many times and still brown foam in the tank.
5. Today I have about an inch of oil sat in the top of the expansion tank.
Any thoughts? I'm stuck now. :confused:
Cheers!
Gary
Re: Head Gasket? Coolant incompatibilty?
I've pressure tested the oil cooler on the water side and no leaks...
Just to be sure I have bypassed the oil cooler. I'm going to see how it goes, but I think I can see oil dripping out of the redundant water take-off. Fingers crossed you're right.
