Re: VAG-COM in Devon/Dorset?
im not sure vag com will do #4. i think you need vag commander
someone please correct me if im wrong...
the first 3 are simple adaptations via vagcom or a diagnostic tool.
number 4 is more than likely going to require an edit of the eeprom (vagtacho or vag can commander will be required)
No, I'm pretty sure I have read that you can change a coding in Coding 17- Insturments to set either nothing lit up, needles only lit up, scala (Numbers) only lit up or both needles and scala lit up.
I will try and hunt out the correct coding for it.
Paul
Knew I had seen it somewhere!!
Select 17 (Instrument Cluster)
Adaptation -> Function 10
-> Channel 19 (Misc)
xxxx?: Remote Clock
0 - Remote Clock not active
1 - Remote Clock active
xxx?x: Ambient Temperature
0 - no Display, Illumination inactive
1 - Display and Illumination active
xx?xx: Driver Information System (DIS)
0 - DIS 1
1 - Highline without DIS
2 - DIS 2
x?xxx: Board Computer
0 - only Level 2 (long time memory)
1 - Level 1 and 2
?xxxx: Illumination Option
0 - Needle and Scala only active at 'Light on"
1 - Needle already active at 'Ignition on'
2 - Scale already active at 'Ignition on'
3 - Scala (2. Map) and Needle at "ignition on" active
glad to be corrected :)
have some rep.
Quote:
Originally Posted by
elPaulio
xxxx?: Remote Clock
0 - DIS 1
2 - DIS 2
1 - Level 1 and 2
It would be nice if you posted the source, in this case:
http://en.openobd.org/audi/a4_8e.htm#17
Note: Illumination Option 3 works on early B6 A4 models, but not necessarily on some of the later ones.
-Uwe-
Hi Uwe,
I would gladly have posted the source if I had been able to find it, I have a copy of this in notepad hence the lack of reference. Many thanks for putting up the link though, I have now added this to my favourites ;)
And Mucho Gracias Dan for your kind rep donation!! ::beerchug::
Great, I had a leon cupra before the audi and this had the lights on all the time. Surprising what stupid little things you miss!
Does anyone know how to make this same change on the A3(8P), or the Golf Mk5 ("same" car).
