A6 Front Door Open Sensor
I have a 2001 "51" plate A6 2.5TDi Avant Quattro Sport. When I open the driver's door, the car does not know it has been opened, but it recognises all other doors opening, with a picture on the dash and the interior lights etc.
I had a quick look but I could not find an obvious switch, which would be activated by opening the door. How does it work?
Regards,
Martin
Re: A6 Front Door Open Sensor
switch is inside the door lock.
each door lock has two micro switches, one triggers courtisy functions, such as the dash, and floor pan lights , the other security functions.
Other famous item that causes this fault is water in the footwell after the drain holes in the pelumn chamber become blocked
