Re: bora water o/s footwell
Do you have a sun roof? I had water everywhere in my car when we had torrential rain due to the blue water hoses being completely blocked... both of them!
In the plenum chamber (drip tray) under the windscreen wiper mechanism there is a plastic cover that is for bringing the wiring through from inside the car. These warp and allow water into the driver’s footwell and this also damages the Convenience unit as well.
no sunroof, i have hopefully cured it! after hosing down the side of wing drain hole and putting news paper daily under rear carpet it seems to be getting dry and no sign of puddles even when raining now, so fingers crossed otherwise i will have to look again, thanks for your advice all.
having the same problems as you ian-and quite bad just wondering if you had any joy in fixing the problem listed above. also is it easy enough lifting the carpets, and did you find the waters point of entry
cheers
]Bora?
yeah unfortunatley!
Usually it is the door panel gaskets.
i did check the doors but they seemed fine.funnliy enough it seem to be drying out now even though its been raining quite a lot-cheers
You could also check the pollen filter housing these are prone to leaking also, espcially if the car has had a new windscreen or wiper mechanism and been disturbed. Just make sure it is fitted correctly.
