Hi guys, just wondering if anyone knows how to remove the dash trim as I can't see a way to do it without damaging it. Couldn't find anything with the search.
Printable View
The long section on the dash require you to remove the centre console and then drop the "cage" down to get up to the clip that resides there.Also the glovebox and drivers side footwell panel will need to be removed.
It will look worse before it looks better
Right ok and how do you remove the centre console lol.
Ok got the centre console and everything out. Is there a special way to take the trim out as they don't seem to just pop out. You were right it looks a lot worse!
