[Removed]
Printable View
[Removed]
Have a quick read of this....
Should be fairly similar ;)
Nick
[Removed]
polo brakes are dead easy!
1 jack your car up and remove the wheels
2 using and allen key undo the two bolts on the back of the caliper
3 carefully lift off the caliper and place it out of the way
4 remove the front pad
5 remove the clips
6. remove the back pad
7 clean the carrier where the pads slot in (i find a flat blade screwdriver does the job well)
8 copper grease the backs of the new pads and also the part of the carrier the pad slides on.
9 fitting the new pads is just the reverse of removal
