gamma radio code
Hi all
Can anyone tell me how to code my radio (if i need to)
I removed the battery to clear the dreaded drain holes and after fitting it all back together the radio shows
"safe" then "1000" . I have the code but the book is in german :aargh4:
:beerchug:
Re: gamma radio code
You need a trip to the ********, I've heard that they will look the code up on VW computer for free , but can't vouch for this myself
good luck
If you have the code as you say, turn on the radio - the word SAFE will appear. After about 3 seconds the 1000 will appear. Use the station buttons 1 to 4 to input the code number. Use button 1 to input the first digit (I think it just scrolls up thru 1-9), button 2 to input the second etc.
Then hold either the search button (double triangles to left of display) or the manual setting button (left or right triangles to the right of the display) for longer than 2 seconds. Release the button.
The manual says a frequency will be shown automatically shortly after a correct code has been input.
That reminds me I need to clear the drain holes - or get out the siphon hose again. Will wait for this rain to finish!
Thanks for that twillcomp, worked a treat, input button is the one on left.
Prevention is better than cure re those drain holes;)
