http://www.pelicanparts.com/ultimate...uploads/vw.jpg
I found this picture, but I am confusing about the step 3. The button I need to press is on the first key in the ignition or the second one?
Printable View
you must press the button on the key fob you used to lock door
This method does not work for my remote control. I tried for several times, but when I pressed the unlock button the horn will sound for a few minutes and the red light was flickering.
To Do This You Must Have 2 Keyfobs,recheck You Have Fitted Battery Correctly To Fob.......switch On Ignition With Working Keyfob,use Non Working Key To Lock D/s Door,with Remote Press Unlock Once Beep Will Sound.....wait 6 Seconds...press Unlock Again To Activate Code. I Have Done This A Few Times Without Any Trouble ......try Again;)
Unfortunately, this method does not work for my remote control too...... I have fitted battery correctly. The beep did not sound when I pressed Unlock. Just the small red LED was flickering. When I pressed the Unlock until the LED stopped flickering, the door opened, but the beep sounded for a long time and the LED was flickering again.....:(
Thank you...This just worked on our MK 4 Golf:beerchug:
Thankyou very much for this info, I have just re synced a key fob to my gt tdi 150 (2003). :beerchug:
